Cannot See Inserted Image
I cannot see the inserted image. When someone answers with an inserted image, what I can see is just an answer and a link symbol.
But I can see the image when browsing from my mobile phone.
Microsoft Edge and Chrome have the same problem.
Did anyone encounter the same issue?
Re: Cannot See Inserted Image
Hi @zouyu930503,
what is your OS?
Romisaa
Both Win10 and Ubuntu 16.04 have the problem.
Hello @zouyu930503 ,
I've also noticed this behaviour last week, where it took some time to link the pic into a post, and then, these aren't added into an actual post.
I've noticed that if i do the second time insertion, and if I look at preview view (as shown below) prior posting a post, the picture appears fine then.
However, i haven't seen this behaviour this week (well, so far).
Can you try once again and let us know if the issue still there for you? Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
@anatoli I mean I cannot see images attached in others' answers.
When I ask a question if someone answers my question with images inserted, then I cannot see the image.
I recently found that when I sign in, I cannot see the image. However, I can see the image when I sign out.
Take your answer as an example:
When I got an email notification that you answered my question, I directly click the link from email without sign-in:
sign-outsign-out
However, when I signed in e.g. to reply your answer, then I cannot see the inserted image, only a symbol:
This problem happens to me for a very long time. Both win10 and ubuntu have the same problem.
Thanks for the clarification on this issue. I have reached out to the Forum Admin team to see if they have a recommendation for you to permanently resolve this behaviour.
I will update you once there are any updates and I hope this is OK with you.
Have a nice day.
Kind Regards,
Anatoli Curran,
Thank you in advance.
