Cannot set MIG into Ping-Pong PHY mode
Ultrascale+ MPSoC design. 64-bit PL-based DDR4 design. 2017.1 using IP Integrator.
I am trying to set the DDR interface to Ping-Pong PHY mode instead of "Controller and Physical Layer".
No matter what I do I cannot get Ping-Pong PHY mode to appear as an option in the Controller/PHY mode drop-down box (which is what PG150 seems to tell me to do). Am I missing something?
Thanks for any help.
Re: Cannot set MIG into Ping-Pong PHY mode
Hi @clivewmwalker
It looks like you are using the MIG IP inside block design. Try generating the IP from IP catalog outside block design.
Deepika.
Hi Deepika.
Yes, you are right. Thankyou.
Seems that I can only select Ping-Pong PHY when instantiating DDR4 MIG in the non IP Integrator flow.
It is also the case that Ping-Pong PHY mode is not available when using the AXI4 interface.
Thinking about it, I guess these two "features" are related. I suppose the core would need 2 AXI interfaces in order to support Ping-Pong PHY with AXI4? This is still conceptually possible, but is clearly more complex. I assume it's just that Xilinx has just not got around to doing this yet? Do we know if Xilinx have any plan to address it? Just curious.
Cheers
Clive
Hi Deepika.
Still concerned. I have an Ultrascale+ IP Integrator .bd design which has a valid PL-DDR4 pinout defined, according to the NON-Ping-Pong PHY mode DDR interface. I used the byte-planner to set this pinout.
As far as I know (through reading and forums etc), there are only 3 pins which need to be duplicated for Ping-Pong PHY support: CSn, CKe and ODT.
Is it safe for me to simply add these additional pins to my existing non-Ping-Pong PHY design? In which case, are there recommended pin locations for the duplicated pins?
Or are there additional pins I am unaware of?
And does the non-Ping-Pong PHY pinout need to change in other ways (eg definition of byte lanes etc) or is it still valid?
I could build a design using the non-IPI core in Ping-Pong PHY mode simply in order to extract a valid placement for the additional pins. but I fear this is error-prone.
Clive
Clearly, there are NO answers to the designer level questions.
