Visitor jgtimms
Clocking DDR data into a FIFO in Spartan 6
I would appreciate if someone could show\tell me how to implement something in ISE\Verilog.
I want to bring the output of an ADC into a Spartan 6 and store it in a FIFO within the FPGA.  The problem I am having is the ADC output data is LVDS and DDR, i.e. new differential data is present and should be clocked into the FIFO on both edges of a 200MHz differential clock provided by the ADC.  How to I update the FIFO on both edges of this external differential clock?
I appreciate your assistance.
Scholar austin
Re: Clocking DDR data into a FIFO in Spartan 6
j,
This will be very difficult, as S6 is not very fast (it is designed for lowest power, lowest cost).  Even in Virtex, this may not be the best way to solve the problem.
Rather, I would store using edge data in one BRAM/FIFO, and falling edge data in another BRAM/FIFO.
Reading back out, I would use the dual port of the FIFO to read both even and odd on a new clock, which is rising edge for both, but half the speed.
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
j,
Austin Lesea
Principal Engineer
Xilinx San Jose
Instructor
Instructor
Why not just use the IDDR2 input registers to feed one FIFO that's twice as wide?
-- Gabor
Teacher eteam00
Spartan-6 is easily capable of handling 400MS/sec DDR data with a 200MHz clock.  There are many MANY examples of source-synchronous design problems similar to what you describe, in these forums, in the Spartan-6 device family docs (see the Clocking Resources User Guide), and in the Spartan-6 reference designs for the various evaluation boards.
-- Bob Elkind
SIGNATURE:
Summary:
Historian
Historian
-- Bob Elkind
The question is not whether the I/O can handle that speed; it's whether he can write to a BRAM or FIFO at that speed.
Visitor jgtimms
This makes sense.  Thank you all.
