wiangtong
Config pin as single-ended io in Zynq7000 (Trenz)
Let me confirm that we have corrected map the FPGA pin in Trenz dev board.
We expect to map (PL->FPGApin->FMCpin
UARTLITE.Tx -> Y18 ->  FMC_LA0_P
UARTLITE.Rx -> Y19 ->  FMC_LA0_N
This case does not  work! as single ended ports. it seems that the voltage level at P is similar to N on the same pair.
However, from the experiments:
TX -> LA0_P, RX -> LA0_N (Not OK)
TX -> LA0_P, RX -> LA1_P (OK)
TX -> LA0_N, RX -> LA1_N (Not OK)
Any special attribute parameters to be defined in XDC?
We need a lot of 3.3V pins as UART outputs. Is it possible to use all pins (both P and N) as a single ended pin?
I appreciate if you have any suggestions.
Best regards,
Yod
balkris
yes its possible you need to convert differential clock to single ended
you can use IBUFGDS for the clock to convert from differential clock to single.
For vivado you can find information here
http://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
ISe design flow
See more description in the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/7series_hdl.pdf (page no. 177)
check this post as well
https://forums.xilinx.com/t5/Implementation/How-do-I-tell-Vivado-that-my-signal-is-differential/td-p/332731
https://forums.xilinx.com/t5/General-Technical-Discussion/The-difference-between-IBUF-IBUFDS-and-IBUFG-IBUFGDS/td-p/310949
Thanks and Regards
Balkrishan
wiangtong
Thanks for you info.
There is no clock signal. We are using UARTLITE ipcore and try to use Tx, Rx as single ended ports.
It doesnot work when we map Tx, Rx on the same P/N pair. Why?
BTW, we are using Trenz TE0715 with Z7030 on board.
Theerayod
balkris
https://forums.xilinx.com/t5/Silicon-Devices-Others-Archived/Boundary-Scan-loading-to-SPI-Flash-failed/td-p/86347
Thanks and Regards
Balkrishan
muzaffer
are you sure the bank which is connected to the fmc connector can do 3.3V IO ?
what you want should certainly work. Just make sure nothing else is connected to the same pins.
