Observer hamdipfe2015
Connect the Ethernet cable to the Ethernet connection on the VSK 3400 hardware board and to the Ethernet port of my laptop.
i make a design with co-simulation Point-to-Point Ethernet block  with system generator on simulink Matlab ,when i want to sent this desgin to FPGA spartan 3a DSP 3400a ,i don't know how to sent this design and how to Connect the Ethernet cable to the Ethernet connection on the VSK 3400 hardware board and to the Ethernet port of my laptop.
any one help me plese wih a tutoriel or video that explain this
Re: Connect the Ethernet cable to the Ethernet connection on the VSK 3400 hardware board and to the Ethernet port of my laptop.
Check Hardware co simulation section of below doc for the process to follow
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/sysgen_user.pdf
Satish
check this guide
http://www.xilinx.com/tools/feature/14_1_isim_hw_cosim_qrg.pdf
Thanks and Regards
Balkrishan
check this guide
http://www.xilinx.com/support/documentation/boards_and_kits/ug217.pdf
Thanks and Regards
Balkrishan
check if your board listed in supported board . Its only supports point to point hardware co-simulation
Thanks and Regards
Balkrishan
