03-02-2016 07:35 AM
Hi all,
I've just trying to create a custom AXI IP using the "Create and Package IP" tool on vivado 2015.4. Everything seem to be pretty similar as on 2014.x vivado version but the difference I found is that the source files are created in verilog.
Is there any way to do the same but with the generated files in VHDL ?
Thanks in advance.
Regards.
03-02-2016 08:06 AM
Hi @jlesquer
What is the target language (in the project settings) set to?
Change it to VHDL and try.
03-02-2016 08:06 AM
Hi @jlesquer
03-02-2016 08:28 AM
Thanks, that solved the problem, I've just updated from 2014 to 2015 version and I was a bit confused with the setup.
Cheers.
