Creating application project at SDK
this is sdk log of my SDK
02:45:00 ERROR : (XSDB Server)No PRESET Parameter : [Low] PresetParam: pcw_ddr_priority_writeport_0
02:45:00 ERROR : (XSDB Server)/opt/Xilinx1/SDK/2016.4/bin/loader: satır 179: 4879 Parçalama arızası (çekirdek döküldü) "$RDI_PROG" "$@"
02:45:00 ERROR : Failed to openhw "/tmp/temp1485217916984/system.hdf"
java.io.IOException: Command [C 15 xsdb eval "::hsi::utils::openhw /tmp/temp1485217916984/system.hdf"...] aborted
at org.eclipse.tcf.core.AbstractChannel$9.run(AbstractChannel.java:838)
at org.eclipse.tcf.EventQueue.run(EventQueue.java:95)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Communication channel is closed by remote peer
at org.eclipse.tcf.core.AbstractChannel$1$2.run(AbstractChannel.java:381)
... 2 more
hi,
what is the version of SDK that you are using?
what is the operating system that you are using?
can you share the hdf?
--hs
SDK 2016.2
Linux ubuntu
you can try with administrative login
There may be permissions issue with your TMP folder:
The SDK tool uses this folder to store the temp MSS while it is getting overwritten, then since there is a persmission issue it is loosing the temp content and therefore the MSS file.
Can you please check if you have access to the folder?
Thanks and Regards
Balkrishan
hi,
confirm if you are using the supported OS for 2016.2
https://www.xilinx.com/support/answers/54242.html
  • Cent OS 6.7 and 7.1 (64-bit)
  • Ubuntu Linux 14.04.4 LTS (64-bit)
--hs
hi,
created a workspace on RHEL OS with your HDF and was able to create a workspace. so please try in a tested OS.
--hs
./rdi_xsdb: error while loading shared libraries: libtcl8.5.so: cannot open shared object file: No such file or directory
test@test-VirtualBox:/opt/Xilinx/SDK/2016.2/bin/unwrapped/lnx64.o$
hi
tank you for fast response ,
it is ubuntu 14.04.4 and it dane same thing in sdk 2016.4 also
