DDS compiler
by using the DDS compiler block in system generator, we can function the PLL concept.
Shark
Re: DDS compiler
yes,
Along with the rest of the design.  The DDS is only the numerically controlled oscillator.
To form the phase locked loop you will also need a phase-frequency comparator, a low pass filter, along with the NCO.
Often there are dividers added to perform frequency synthesis (get a different frequency out than what was used as a reference).
Austin Lesea
Principal Engineer
Xilinx San Jose
Re: DDS compiler
yes,
Austin Lesea
Principal Engineer
Xilinx San Jose
