naveengk14
Difference between simple and true dual port RAM
Hi all,
what is the difference between simple and true dual port RAM..?
Naveen G K
vsrunga
@naveengk14 Simple dual port RAM woudl have one write and one read port where as true dual port has independent write and read ports for both the ports.
Please refer PG058 for more details
http://www.xilinx.com/support/documentation/ip_documentation/blk_mem_gen/v8_3/pg058-blk-mem-gen.pdf
yenigal
Check below link
https://forums.xilinx.com/t5/Virtex-Family-FPGAs/Difference-between-BRAM-configurations-TDP-vs-SDP/td-p/325551
Satish
