vaddi_iitg
Differential clock to single ended Clock
Hi all I am using a zynq zc702 board. I have a differential clock comming from the board. now i want to make it into a single clock. Now i know that there are several buffers like IOBUF, IBUFGDS,IBUFDS etc... What are the difference between these. And which should i use.
anusheel
Clock constraints do not results in IOSTD errors.
As this issue is already active on other thread, close this thread by marking the solution.
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
vuppala
you can use IBUFGDS for the clock to convert from differential clock to single.
See more description in the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/7series_hdl.pdf (page no. 177)
Vinay
pulim
yes, you should be using IBUFGDS.
This design element is a dedicated differential signaling input buffer for connection to the clock buffer (BUFG) or
MMCM.
IOBUF is a bidirectional single-ended I/O Buffer used to connect internal logic to an external bidirectional pin.
IBUFDS is differential signalling input buffer that is used differential inputs.
vaddi_iitg
But i have a problem. IBUFGDS template is not there in Vivado. And if i am using IBUFDS i am getting this error while generating bitstream
  • [Drc 23-20] Rule violation (IOSTDTYPE-1) IOStandard Type - I/O port systemClockN is Single-Ended but has an IOStandard of LVDS_25 which can only support Differential
    • [Drc 23-20] Rule violation (IOSTDTYPE-1) IOStandard Type - I/O port systemClockP is Single-Ended but has an IOStandard of LVDS_25 which can only support Differential
anusheel
This error may occur if I/O port is single ended and LVDS_25 is used thats what error message says.
Make sure you are using right constraints. Which device are you targeting? Show your constraints here.
Anusheel
vaddi_iitg
I am using ZC702 board. I am using System Clock. In use Guide pg 28. D18 and C19 for P and N. But i did not give clock constraints is that the problem??
anusheel
Anusheel
vemulad
Open synthesized design and check if the IBUFDS inputs and output are connected properly or not.
Deepika.
Deepika.
