naveengk14
EDIF File
How to generate EDIF file in Vivado ?
How to call the EDIF file ?
Naveen G K
arpansur
Hi @naveengk14,
Open synthesized design.
 Use Tcl command write_edif <top module name>.edf
You can use it in post_synth project or you can include in design sources with a stub.
Arpan
naveengk14
what is the command to call the edif file in TCL script.
Naveen G K
syedz
@naveengk14,
read_edif
Check page number 986 in below user guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug835-vivado-tcl-commands.pdf
--Syed
arpansur
Hi @naveengk14,
What do you mean by calling the EDIF files?
Is it adding EDIF as source file to project or using EDIF in non project mode?
You can use add_files or read_edif as suggested by @syedz.
Please go through page-58 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug835-vivado-tcl-commands.pdf for info on add_files
Arpan
saradapr
Hi @naveengk14,
Please check similar post may help.
https://forums.xilinx.com/t5/7-Series-FPGAs/how-to-use-a-edif-file-in-vivado/td-p/561686
Sarada
arpansur
Hi @naveengk14,
Were the suggestions provided helpful?
Arpan
