rahmah.umamah
EOL Replacement
I'm new here. My name is Rahmah, Component Engineer for Rapiscan Malaysia.
Our company using below EOL/NRND IC. Please anyone suggest close replacement
1. Xilinx XC17S200APD8C (EOL 31 Dec 2015)
2. Xilinx XC2S200E-6PQ208C (EOL 31 May 2013)
3. Xilinx XCR3128XL-10TQ144I (NRND - soon to obsolete?)
Many thanks.
Rahmah
vuppala
Hi @rahmah.umamah
Contact your FAE for this information.
Vinay
athandr
FAE is the right person for this. However for 2 there is no direct replacement. Check pg 14 table 11 - http://www.xilinx.com/support/documentation/customer_notices/xcn12026.pdf
Anirudh
athandr
Check - http://www.xilinx.com/support/documentation/customer_notices/xcn07010.pdf if you can find something for point 1 device.
Anirudh
rahmah.umamah
Hi Vinay,
Many thanks. Any suggestion how to find for nearest IC so we can redesign our board?
Rahmah
rahmah.umamah
Hi Anirudh,
Many thanks. Any suggestion nearest IC for redesign?
Rahmah
athandr
No, the FAE's should be the correct contacts for this as discussed.
Anirudh
