Visitor harsha216
ERROR: [Common 17-70] Application Exception: Failed to stitch checkpoint 'mem.dcp' at cell 'I_ram'.
Hi I have generated block rams for my design. The synthesis was complete without any errors.
But when I try to open the synthesized design, I get the following error:
I am not able to see the synthesized design due to this error.
What am I missing?
Re: ERROR: [Common 17-70] Application Exception: Failed to stitch checkpoint 'mem.dcp' at cell 'I_ram'.
@harsha216
This error message is issued when:
  • an IP core in the design is synthesized as an out-of-context (OOC) module and
  • the synthesized OOC for the IP core results in an empty dcp (Synthesis removes all logic when synthesizing the files delivered for the IP core).
 When Vivado is trying to open the design it is unable to handle/integrate the empty dcp so it fails with the above error.
Workaround:
  1. Select the IP instance in the hierarchy view and unset out-of-context module by right clicking on it.
  2. Now use the IP catalog to create the IP with the same name
  3. Generate the IP
  4. Add the IPname_stub.v file to the project available in the IP location
  5. Remove the already added IPname.v file from the project
  6. Now Synthesis and implement the design.
--Syed
@harsha216
Workaround:
  3. Generate the IP
--Syed
