rodrigo_varela
ERROR: [Common 17-70] Application Exception: SrcMgr::createSS : name already exists
I started to get this error while openning project in Vivado after merging changes to project_file.xpr
I returned back to original changes but still cannot get Vivado to open the xpr file
hope you can help
vuppala
Hi @rodrigo_varela
1. Are you getting this error message even if you try to open an example project as well?
2. Are you able to run vivado in tcl mode?
3. Change the project directory and see if the issue still occurs?
4. Share vivado.log file here.
5. Which OS and Vivado version are you using?
Vinay
rodrigo_varela
Hi Vinay,
I was getting this when opening a project only under a workspace.
I moved to a differnet folder (workspace) and used the old.xpr so I could continue.
The message in the subject line was all the vivado.log file had inside.
Currently I am running vivado on Suse linux.
Thank you
RV
nupurs
Hi @rodrigo_varela,
Which exact version of Vivado and which exact version of SUSE linux are you using?
Nupur
