08-24-2016 03:04 AM
I found the following problem:
ERROR:Simulator:861 - Failed to link the design
Process "Simulate Behavioral Model" failed
it was running on machine with winxp, ise 12.1
Can anyone help to solve it ?
Best Regads,
Marc
08-24-2016 03:17 AM
Try creating the project from scratch and see if that helps.
Also,
1. Can you try running ISIM in command line mode.
2. Try runnning ISIM in 32-bit mode (Start --> All programs --> Xilinx Design Tools --> ISE Design Suite 12.1 --> 32-bit Project Navigator)
08-24-2016 03:39 AM
08-24-2016 03:40 AM - edited 08-24-2016 03:42 AM
I would recomend you to use ISE 14.7 or vivado latest version
ISE 12.1 is obsolete version and not recommended to use
ISE also support third party simulator like VCS , Modelsim, questa . You can alternate simulator .
08-24-2016 11:04 AM
Which ISE version is it failing with?
Make sure you use one of the supported OS for that version of ISE.
It is always better to go for the latest version i.e. ISE 14.7 and use supported OS.
08-26-2016 04:32 AM
Did you get the issue resolved?
Let us know if you need help.
