Error: call to clGetDeviceIDs() returns CL_DEVICE_NOT_FOUND
I am using SDAccel and am trying to execute the example code "matrix_multiply_cl_kernel" in the alpha-data card.
  • For doing so, I run "sdaccel example_alphadata.tcl" with no problems.
  • Then install driver and set the environment following this guide (v2015.03): SDAccel Development Environment: Tutorial
  • I checked if the alpha-data card is detected by Linux (the firmware was already installed):
$ lspci -v
01:00.0 Memory controller: Xilinx Corporation Device 7038
	Subsystem: Xilinx Corporation Device 0010
	Flags: bus master, fast devsel, latency 0, IRQ 129
	Memory at df000000 (32-bit, non-prefetchable) [size=4M]
	Memory at df400000 (32-bit, non-prefetchable) [size=1M]
	Capabilities: <access denied>
	Kernel driver in use: xdma
	Kernel modules: xdma
  • After that I got the XILINX_OPENCL and LD_LIBRARY_PATH variables set to specific values. The problem appears during execution (under <solution>/pkg/pcie/):
$ ./example_alpha.exe mmult1.xclbin
CL_PLATFORM_VENDOR Xilinx
CL_PLATFORM_NAME Xilinx
Error: Failed to create a device group!
Test failed
Segmentation fault (core dumped)
  •  Debugging the application, I found that the it fails calling clGetDeviceIDs(), because it returns -1 which means CL_DEVICE_NOT_FOUND.
  // Connect to a compute device
  int fpga = 0;
#if defined (FPGA_DEVICE)
  fpga = 1;
#endif
  err = clGetDeviceIDs(platform_id, fpga ? CL_DEVICE_TYPE_ACCELERATOR : CL_DEVICE_TYPE_CPU,
                       1, &device_id, NULL);
  if (err != CL_SUCCESS)
    printf("Error: Failed to create a device group!\n");
    printf("Test failed\n");
    return EXIT_FAILURE;
I also tried other Xilinx examples and they fail executing clGetDeviceIDs(). I revised other forums and many people solve clGetDeviceIDs()-related issues by (1) finding the number of platforms in the system and (2) choosing the right one to work with.
However, I have verified with clGetPlatformIDS(), that I have only the Xilinx platform in my system.
Is there anything I am missing?
Any suggestion will be welcome!
Leonardo
Best,
L30nardo SV
Newbie qiaofei
Re: Error: call to clGetDeviceIDs() returns CL_DEVICE_NOT_FOUND
Hi~
I just got the exactly same problem with you and still have no idea. Have you figured out any solutions?
Best wishes,
Fei Qiao
I still have the same problem.
I was told to re-installed the generated firmware (located in /pkg/pcie) but it doesn't work.
I was thinking, the problem is the host OS.
I am using Fedora. What about you?
Leo
Best,
L30nardo SV
