Error in ise for a embedded processor system
I added a .xmp file from xps to ISE-14.2 , it is having a peripheral attached with the microblaze.
While translating it is giving error like :
ERROR:EDK - :EDK:4110 - IPNAME: mesh3, INSTANCE: mesh3_0 - cannot find MPD for
the
pcore 'mesh3_v1_00_a' in any of the repositories -
C:\Users\mnit\Documents\noc\final_noc\system.mhs line 523
version not verified on hardware for architecture 'kiERROR:EDK - :EDK:4110 - IPNAME: mesh3, INSTANCE: mesh3_0 - cannot find MPD for
the
Running UPDATE Tcl procedures for OPTION TESTBENCHGEN_SYSLEVEL_UPDATE_PROC...
ERROR: xps 'run memgen' call failed
ERROR: XPS process failed to run memgen.
ERROR: Generating the mem file for block ram initialization for C:/Users/mnit/Documents/noc/final_noc/system.xmp failed.
Please help.
Thank you.
Re: Error in ise for a embedded processor system
@vaishalijhalani1@gmail.com
Is mesh3 your custom IP?
Make sure you place the custom IP in the project pcores directory or in the XPS install pcores directory
Custom IP :https://www.youtube.com/watch?v=MC1amstP_8A
Refer to the similar  discussion in the thread http://forums.xilinx.com/t5/Embedded-Development-Tools/ERROR-EDK-4110-in-XPS/td-p/559438
Achutha
yes,mesh3 is my custom ip and it is there in the pcores folder.
hi,
can you launch the embedded design in XPS and try to run Project --> Design Rule Check in XPS GUI?
confirm if you are following the procedure documented in this PDF?
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_3/edk_ctt.pdf
--hem
there is no error during DRC in xps.
Is the XPS design/IP migrated from one version to other ?
Does re-creating the custom IP in the current version resolve the issue?
Achutha
No , i created in the current version only .Then instantiate it to ISE.
I have seen a similar issue in 13.x and 14.1 version of XPS/ISE.
This is seen because platstudio run targets(including stubgen, memgen, testbenchgen) was not inserting library paths(global, project specific ). But memgen do accepts -lp path, so if  running from command line it will work.
Since you are running in ISE flow this may not be an easy workaround.
Can you try open XPS project and select Project options  and un-check generate test bench template and see if that helps?
These issues are seen moslty in the design migrated from older version to the newer version.
Achutha
As you said,i did this step but still getting this error.
