Error running SDAccel for hardware emulation
I am running SDAccel in Fedora (kernel 4.0.4-301). I have problems running the example: "sdaccel board_compile.tcl", everytime i try it, it hangs when loading the kernel file.
This is the console output during hw emulation:
INFO: [SDAccel 60-348] Executing hardware emulation using software accelerators...
INFO: [SDAccel 60-280] Additional args : '-d acc -k test.xclbin'
INFO: [SDAccel 60-174] Running emulation command line: /home/lvs/SDAccel_examples/getting_started/board_compilation_solution/impl/sim/hw_em/newboard_compilation_solution.exe -d acc -k test.xclbin
Input sequence1: TAGGCAAGACCACTTTAGCATGGTCTACAACGCCTAGACCTTTGGCAAAGCAGATCGGCCCGCCCATCACTAGTGGGACTATCC
Input sequence2: TAATGGGAACACCTGCTGCAATCGGATCGTTGCAGCGGTAATGTGTCGGTATATGCGAGTAGGGTAATCCAAACGTCCCATTGC
Platform = Xilinx
Device = fpga0
OpenCL Version = 1.0
Loading test.xclbin
The emulation is stuck at that point and doesn't proceed.
When i enabled debug during hw emulation, I found that the application hangs when clCreateProgramBinary is called (oclHelper.cpp/ line 182)
    if (deviceType == CL_DEVICE_TYPE_ACCELERATOR) {
        size_t n = size;
        soft.mProgram = clCreateProgramWithBinary(hardware.mContext, 1, &hardware.mDevice, &n, (const unsigned char **) &kernelCode, 0, &err);
Any suggestions please??
Best,
L30nardo SV
Re: Error running SDAccel for hardware emulation
Could you try using lab 1 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug1021-sdaccel-tutorial.pdf ?
It may help you.
Praveen
Helpful answer -> Give Kudos
Thanks pvenugo, but that tutorial corresponds to SDAccel 2015.1.
I am currently using SDAccel 2015.3, I followed all instructions provided here: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/sdaccel_doc/index.html.
I am not able to proceed. Any other suggestion will be welcome.
Best,
L30nardo SV
SDAccel only officially support RHEL or CentOS 6.4-6.7 (kernel 2.6.32). Can you try it on a machine with supported OS? Which version of Fedora are you running? Going forward, please use the HLS board below for SDAccel questions for now. We are in the process of creating a SDAccel board for SDAccel users. Stay tuned.
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
Platform = Xilinx
Device = fpga0
Loading test.xclbin
        size_t n = size;
Cheers,
Jim
Hi Jim,
Thanks for the info.
I can not try sdaccel on a different machine. My machine has Fedora 23 (kernel 3.13.5).
Regards, Leonardo
Best,
L30nardo SV
Hi Leonardo,
SDAccel is not tested with Linux kernel 3.x. We will look into supporting that, but for now your best bet is to install a supported Linux version. Sorry.
Hi Jim,
Regards, Leonardo
Cheers,
Jim
