sjvengatesh
Error showing verify.dll is not valid windows image immediately after installing vivado 2014.4
We are getting the error message showing
"C:\Xilinx\Vivado\2014.4\tps\win64\jre\bin\verify.dll " is not valid windows image immediately after installing vivado 2014.4.
Iam installing the vivado 2014.4 software in Windows XP 64 bit edition.
I am attaching the screenshot of the error message.
Please help us to rectify this issue.
vijayak
Hi @sjvengatesh
For the Vivado 2014.4 release, Windows XP will no longer be supported. This is due, in large part, to Microsoft’s termination of Windows XP support.
Refer to release notes page 9 for information related to http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug973-vivado-release-notes-install-license.pdf.
Try using supported OS.
Thanks,Vijay
