Anonymous
Not applicable
Errors Generating Libraries and BSPs
Hi everyone,
I have these errors when Generating Librairies and BSPs:
WARNING:MDT - PORT:IWAIT CONNECTOR:ilmb_LMB_Wait -
   /opt/Xilinx/10.1/EDK/hw/XilinxProcessorIPLib/pcores/microblaze_v7_10_a/data/m
   icroblaze_v2_1_0.mpd line 196 - No driver found. Port will be driven to GND!
WARNING:MDT - PORT:DWAIT CONNECTOR:dlmb_LMB_Wait -
   icroblaze_v2_1_0.mpd line 232 - No driver found. Port will be driven to GND!
WARNING:MDT - PORT:bscan_tdo1 CONNECTOR:bscan_tdo1 -
   /opt/Xilinx/10.1/EDK/hw/XilinxProcessorIPLib/pcores/mdm_v1_00_b/data/mdm_v2_1
   _0.mpd line 197 - No driver found. Port will be driven to GND!
WARNING:MDT - PORT:I_ADDRTAG CONNECTOR:ilmb_M_ADDRTAG -
   icroblaze_v2_1_0.mpd line 194 - floating connection!
WARNING:MDT - PORT:D_ADDRTAG CONNECTOR:dlmb_M_ADDRTAG -
   icroblaze_v2_1_0.mpd line 235 - floating connection!
WARNING:MDT - PORT:bscan_tdi CONNECTOR:bscan_tdi -
   _0.mpd line 190 - floating connection!
WARNING:MDT - PORT:bscan_reset CONNECTOR:bscan_reset -
   _0.mpd line 191 - floating connection!
WARNING:MDT - PORT:bscan_shift CONNECTOR:bscan_shift -
   _0.mpd line 192 - floating connection!
WARNING:MDT - PORT:bscan_update CONNECTOR:bscan_update -
   _0.mpd line 193 - floating connection!
WARNING:MDT - PORT:bscan_capture CONNECTOR:bscan_capture -
WARNING:MDT - PORT:bscan_sel1 CONNECTOR:bscan_sel1 -
   _0.mpd line 195 - floating connection!
WARNING:MDT - PORT:bscan_drck1 CONNECTOR:bscan_drck1 -
   _0.mpd line 196 - floating connection!
Performing Clock DRCs...
ERROR:MDT - standalone () - ERROR: ld.so: object
   '/opt/Xilinx/usb-driver/libusb-driver.so' from LD_PRELOAD cannot be preloaded
   (wrong ELF class: ELFCLASS64): ignored.
       while executing
   "exec bash -c "$archiver -d ../../lib/libxil.a _interrupt_handler.o""
       (procedure "::sw_standalone_v2_00_a::post_generate" line 19)
       invoked from within
   "::sw_standalone_v2_00_a::post_generate 103630096"
Please help me solve it. I am running 10.1 SP3 on Debian.
htsvn
hi,
would that be possible to try this on a different machine with an operating system?
--hs
Anonymous
Not applicable
I tried this on another machine with Debian 64bit, and I still got the same error.
I think that the error is from the usb-driver which I downloaded from internet. I am wondering if there is a working version of the usb-driver downloadable somewhere.
sampatd
Anonymous
Not applicable
Hi Sampatd,
I checked the discussion, but I could not find a solution for my case.
sampatd
Can you archive the SDK workspace and attach it here? I can take a look.
Anonymous
Not applicable
Here is the archive. Please have a look:
http://www.mediafire.com/download/vzbj5p4l88333d9/webserver.7z
htsvn
hi,
thanks for the files. i have run this on a RHEL OS and was able to compile the Libraries without any error.
Would that be possible to try this on a supported OS?
--hs
