Ethernet communication (spartan 3a dsp fpga 1800a -UG454 evaluation board)
sir,
   i am trying to implement ethernet transmision from our FPGA board to pc .  i done the following
1. I create "Trimode ethernet mac ip".
2.I created bit file of example design file (vhdl file) without doing any modification in both program as well as its generated ucf.
3. i found the generated ucf is having different pin location than the specified pin in schematic.
 these are the doubts for me to clarify
1. how i get the mac address of board. the board is not having any specification about its mac.
2. i am not using any soft processor. so may i able to sent a single packet of udp data from board to pc as starting step?
3. what is the starting step for ethernet transmission
4. How i set ip address?
5. what are the changes that i have to do in address swap module?
i am thankful if you are replying me with details of all of my doubts.
