oryan_ye
FFT 9.0 Vivado result
I would like to get some help please with IP FFT 9.0 in vivado,
I used the simulation provided after creating the IP, and I ran the simulation successfully.
all the signals seems to be perfoming well, BUT
how can i see the result of the FFT??
in other words, how can i see the frequencies of the signals?
i tried to read and search for answers but couldn't find any,
my best guess is that it showed in op_data, but still couldn't see the frequencies.
Thank you,
Oryan.
muzaffer
the output should be in m_axis_data_tdata. Of course it's a complex output so you need to run it through absolute and phase functions to make sense of it.
Have you read chpter 2 of http://www.xilinx.com/support/documentation/ip_documentation/xfft/v9_0/pg109-xfft.pdf
muzaffer
balkris
check the data format structure in product guide . FFT core also provide you example design/test bench to run the simulation
Thanks and Regards
Balkrishan
oryan_ye
ok, i think i got it. as you already realized i'm pretty new to Vivado...
i couldn't find the actual answer i was looking for.
i've read chapter 2 after your attention, I understood that i have to take from the re' and im' only the bits 11 downto 0.
after this i should do the abs and i get the result per sample.
is that right?
muzaffer
that sounds about right.
mohamed.shfat
Hello sir
Sorry for interrupting , but i need to ask something . May please explain to me why we should take the first 11th bits only from each re and im parts ?
