Visitor salmanali08
Failed export compliance verification
I am trying to download vivado 2015.3 webpack but when I sign in it gives me following error
"We cannot fulfill your request as your account has failed export compliance verification. Please visit http://www.xilinx.com/support/answers/44043.html for a possible solution to resolve this error."
I have visited the aboved mentioned page to resolve this issue but no success.
Kindly help me to resolve this.
Re: Failed export compliance verification
Hi @salmanali08
Recently we have seen few login with these issues. I have sent you a private message. Please check.
Thanks,Vijay
Hi @salmanali08,
A similar thread below. It might be helpful to you.
https://forums.xilinx.com/t5/Welcome-Join/Export-Compliance-Verification-failed/m-p/652777
Arpan
Arpan
Hi @salmanali08
Thanks,Vijay
Hi @salmanali08
Please close the thread by marking the solution in the interest of other users.
Thanks,Vijay
I'm having a similar problem... I can't even add a ticket as this fails the same verification. I'm hoping to get this resolved through this forum. Thanks....
Newbie omh1982
Similar issue, happens while trying to sign up for XUP. Can't even submit a ticket due to same issue. I emailed XUP support almost a week ago with no response. Would appreciate some help on this issue.
Newbie omh1982
I have to say that dealing with or even trying to get Xilinx support has been in the past and still is an extremely frustrating process. Since I've faced this issue in particular I sent an email to XUP support and have not received an answer yet. I tried calling the support number but can't talk to anybody without having a support case number. Though I can't create a support case number because I am receiving the same message that I am contacting about in first place. At this point it just feels like Xilinx is deliberately blocking most customer support channels. Does anybody know of a better way to approach this or even of a way to escalate?
Hi @omh1982,
Did you happen to go through http://www.xilinx.com/support/answers/44043.html ?
Please verify in case your country belongs to D and E category.
If your country is not in D and/or E list then please share your username and email-ID used for logging into Xilinx account.
Arpan
Newbie omh1982
Hello @arpansur,
Yes I did go through it but it is not clear by any means. It states that "Furthermore due to strict export control policy, it is no longer possible to create or to maintain an online account in some E or D category countries". "Some" meaning not all but it does not specify which exactly. Moreover, my country is listed in both B and D but not in E if that means anything.
Hi I want to regenerate the license file. However I also face the same problem as stated in this thread.
Can anyone help me to resolve this? thanks.
I am facing the same issue. I have tried with different inputs but the form still says "failed export compliance verification". This is very depressing. Kindly help me as well.
Thanks and Regards
Hi @theumairahmed,
From the AR#44043
Florent
Newbie kuanysh23
How to download Vivado Design Suite? Our country Kazakhsrtan in A and D groups.
Newbie raza
I wanna download Vivado soft wear 2014 14.2 , but facing a kind of issue while downloading. Its about i am " Failed export compliance verification" .. can anyone guide me how i come up with this issue. and can download..
Hello @raza,
Unfortunately, due to strict internal export control policy, it is no longer possible to maintain an online account in some E or D category countries.
The country that you are trying to obtain Xilinx license/software from has been identified as a D category county.
That is the reason for this error regarding export compliance that you are seeing.
For more info, please go through the link below:
http://www.bis.doc.gov/index.php/forms-documents/doc_download/944-740-supp-1
The Answer Record in the error message also explains this situation: http://www.xilinx.com/support/answers/44043.html.
Kind Regards,
Anatoli Curran,
Newbie dr.awais
I am getting same error!
