Hello I am trying to implement a turbo decoder using max log map bcjr algorithm in fpga .I am getting errors when i am checking syntax.Help me to remove the erors.
The errors are
ERROR:HDLParsers:851 - "H:/project/turbo_decoder/Max_Log_Map_Decoder_Block_Codes.vhd" Line 106. Formal ADDRESS_B of H_Matrix_ROM with no default value must be associated with an actual value.
ERROR:HDLParsers:850 - "H:/project/turbo_decoder/Max_Log_Map_Decoder_Block_Codes.vhd" Line 119. Formal port STATE_METRICS does not exist in Component 'Recursion_Unit'.
ERROR:HDLParsers:850 - "H:/project/turbo_decoder/Max_Log_Map_Decoder_Block_Codes.vhd" Line 120. Formal port PN_OUTPUT does not exist in Component 'Recursion_Unit'.
