Visitor qscgy246
How to add Source file
Hi!
I tried to Creating  Custom AXI Slave Interfaces Part2 (Lesson6) video.
I want to add a CountNumberOfPattern file to the myip_v1_0_S01_AXI_inst file like under the attachments.
How can i add the file?
Re: How to add Source file
Hi @qscgy246,
Do you mean you want to add .v or .vhd file to a custom IP?
Add the file in source window. If the file is reflected in hierarchy then it should get reflected while packaging the IP.
If you already have the custom IP then open it in IP packager then add the required files.
Save changes and repackage the IP.
Arpan
Arpan
@qscgy246,
In the IP Packager under File groups, Right click on the File group (VHDL Synthesis) and select Add FIles.
--Syed
Visitor qscgy246
i want to add .sv file
add files click then doesn't exist .sv file
Hi @qscgy246,
Please see the discussion below link:
https://forums.xilinx.com/t5/Design-Entry/Interesting-System-Verilog-files-with-v-extension/td-p/401311
Sarada
Visitor qscgy246
that is not my concern
i want to .sv file conbine .v file
please open the my attachment image
