Observer accord123
How to configure IPv6 for zynq
Hello everyone,
I have to configure ipv6 for the zynq processor. Are there any documents available to refer for ipv6 implementation?
Can anyone suggest how to start ipv6 configuration in SDK?  Is there any macro that has to be set for IPv6?
Requesting to, suggest few guidelines to start with IPv6.
Thanks in advance.
Re: How to configure IPv6 for zynq
Hi @accord123
Please refer XAPP1026 the IPV6 support for Zynq.
http://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
http://rtos.com/PDFs/NetX-Zynq_White_Paper.pdf
Sarada
Observer accord123
Hi ,
Thank you so much for your shared links.
Hi @accord123,
Hope the shared info was helpful to you? If yes, please close the thread by marking the Accepted solution.
Sarada
Observer accord123
Hi Sarada,
The above documents are helping towards understanding the topic.
But, I didn’t get how to enable IPv6 in Vivado-SDK. All the IP configuration files are, by default mapped to ipv4. How to change these default files to ipV6?
Is I have to enable any MACRO in opt.h or lwipopts.h or in any other files?
When I included IPv6 functionalities in the code, compilers is not recognizing them. So what other changes that i have do in the lwip library?
Can you please suggest some "required modifcations in the SDK library"!
