naveengk14
How to fix setup and Hold volation
Hi all,
How to fix setup and Hold volation...?
Naveen G K
arpansur
Hi @naveengk14,
If you want to get more idea on timing closure please go through following links
http://www.xilinx.com/training/fpga/timing-closure-video.htm (ISE)
http://www.xilinx.com/training/vivado/vivado-timing-closure-techniques-physical-optimization.htm (Vivado)
Please let us know your exact requirement and the tool you are using to suggest you in better way.
If possible please share the timing report.
Arpan
Arpan
naveengk14
hi,
Please find below attachement...
Slack (setup path): -1.537ns (requirement - (data path - clock path skew + uncertainty))
   Source:               dec_WRP/header_validin_sig (FF)
   Destination:          dec_WRP/header_sig1_15 (FF)
   Requirement:          6.250ns
   Data Path Delay:      6.994ns (Levels of Logic = 1)
   Clock Path Skew:      -0.758ns (0.778 - 1.536)
   Source Clock:         i_deserial_clk_50M rising at 0.000ns
   Destination Clock:    i_deserial_clk_50M falling at 6.250ns
   Clock Uncertainty:    0.035ns
   Clock Uncertainty:          0.035ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
     Total System Jitter (TSJ):  0.070ns
     Total Input Jitter (TIJ):   0.000ns
     Discrete Jitter (DJ):       0.000ns
     Phase Error (PE):           0.000ns
Naveen G K
arpansur
Hi @naveengk14,
Can you please try with smart explorer and let us know if it resolves your issue.
To get more details on smart explorer please go through the following links
http://www.xilinx.com/itp/xilinx10/isehelp/ise_c_using_smart_xplorer.htm
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/ug689.pdf
Please let us know if you need more clarification on the above details.
Arpan
Arpan
arpansur
Hi @naveengk14,
From the timing report what I can understand is only set-up violation is there. May be packing the logics tightly from the failing path will help to meet timing.
Please go through following link. It gives some recommendations to meet timing closure. Hope this will be helpful to you
http://www.xilinx.com/itp/xilinx10/isehelp/dec_c_timing_closure_recommendations.htm
If possible please share your archived design file here.
Arpan
Arpan
naveengk14
Hi arpansur,
Thanks..
Problem is solved by using smartxplorer,
Naveen G K
arpansur
Hi @naveengk14,
That's great. Glad to know your issue is resolved.
As your issue is resolved please close this thread by marking "Accept as solution" to the answer that led you to solution.
Arpan
Arpan
