robstewartuk
How to interpret resource utilisation numbers from Xilinx ISE
I'm new to FPGA programming. I have a design in VHDL, in Xilinx ISE. My synthesis results include: FF, LUT, memory LUT, I/O, BRAM, DSP48, BUFG.
I'd really appreciate pointers to documents and resources that will help me interpret what the numbers next to each utlised resource mean? Specificaly: 1) what do each of them mean?, 2) are they explicitly used in th VHDL code, or has ISE chosen (e.g. the number of DSP48s) the resources to implement my design?, and 3) if my design is above 100% resource utilisation, how can I change my VHDL code to reduce the use of each resource in turn?
Thanks!
yenigal
1.The numbers indicate total number of each type of resource (LUT,BRAM...) needed to implement  your logic.
2.You can either use the DSP48 primitives directly in the code by instantiation and the tool will also infer and use the DSP48 blocks automatically base on your logic.
3.It depends on which kind of resources that are over utilized...BRAM,DSP48 blocks can be implemented in the LUT andd FF logic resources
Satish
