@sidda123
How to reduce router runtime in vivado....???
  I have built my design using Vivado 2016.1 with AXI BUS interface.
I have used 2 BRAM Controllers, 1 Microblaze Processor. The design is successfully synthesized.
But the Vivado tool is not comming out of ROUTING process.
Can anybody help us to come out of routing Process . Below i have attached Warning message Screenshot.
syedz
@sidda123,
To enable the flag you should actually be using the below TCL command in the Vivado TCL console:
set_param route.enableHoldExpnBailout 1
--Syed
vuppala
Hi @sidda123
As warning specified, did you try by turning on the flag route.enableHoldExpnBailout?
Vinay
@sidda123
Hi @vuppala
I searched for that option ("route.enableHoldExpnBailout") , but i didn't get it.
Can you please help us to find that flag option. where can i get it...???
nupurs
Hi @sidda123,
Type this in tcl console:
set_param route.enableHoldExpnBailout 0
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
syedz
@sidda123,
--Syed
jcmoctezuma
Where can I get information or the complete list about the parameters I can use and their meaning, for example "enableHoldExpnBailout" parameter, which document comes that information?
JC
