How to set a value of a signal from AXI GPIO
I have used AXI GPIO , DMA and custom Ip in vivado design. In my IP, i used a
     signal size:unsigned (7 downto 0);
    and connect that signal with GPIO_O port (set as output).  Now from Sdk, i want to set the value of that signal through AXI GPIO . and written a code like that :
  u32 *GPIO;
  GPIO= (u32 *)XPAR_AXI_GPIO_0_BASEADDR;
    Xil_Out32 ( XPAR_AXI_GPIO_0_BASEADDR , 8 );
       for (Index = 0; Index < 4; Index++) {
        xil_printf( "GPIO  %x \r\n", GPIO[Index]); }
but  i see the output everytime  as : 0, FF, 0, 0
 so it just show me the direction of GPIO, not the value. How to see the value and set it ? Is it a right method ?
Kindly clear my confusion.
hi,
an easier way to do this is to look at an example for one of the development boards with GPIO configured as output{LED}
http://www.xilinx.com/support/documentation/boards_and_kits/kc705/2014_3/xtp195-kc705-bist-c-2014-3.pdf
refer to LED test and the source code of it.
--hem
