How to write a data into block memory using fpga and send it to arm?
    How to write a data into any memory location of block memory using fpga and send it to arm so that arm will read the data from that memory location?
Deepak
Re: How to write a data into block memory using fpga and send it to arm?
You can use data2mem to create a mem file.
data2mem -bm test.bmm -bd test.rlf -bx
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/data2mem.pdf
Thanks and Regards
Balkrishan
You can write to a Dual port BRAM.
You can create a simple IP that does the writing on Port A. Basically you need to generate required signals to write to BRAM (CLK, reset, en, w_en(3:0), data(), address()) .
The Port B is connected to AXI controller which is connected to AXI GP.
Best Regards,
A
