How to write a number in register that present in FPGA and after writing how i can see that number is written or not?
     How to write a number in register that present in FPGA and after writing number how i can see the that number is written or not in that register?
Deepak
Re: How to write a number in register that present in FPGA and after writing how i can see that number is written or not?
@deepak1991,
You can set the INIT value for that register. Example:
set_property INIT 1'b1 [get_cells <register_name>]
For verifying, you can select the register in schematic and check the INIT value under its properties.
Nupur
Hi @deepak1991,
In the netlist you can use below Tcl command to initialize a flop.
set_property INIT 1'b1 [get_cells <name> ]
Similarly to get the value you can use
get_property INIT [get_cells <name> ]
Arpan
Hii Nupur,
You have any example for this please send it to me.I am new to fpga so i don't know how to start it.
@deepak1991
Open synthesized design, select a register. You can see its name in properties.
then type this in tcl console: (in my case reg name is A_reg[0].
set_property INIT 1'b1 [get_cells {A_reg[0]}]
Nupur
Hi @deepak1991,
Attached is a small testcase with a single register.
  1. Create a project
  2. Add file
  3. synthesize the design.
  4. Open synthesized design.
  5. Click on the schematic and highlight b_reg. You will INIT value in property window is 1'b0
  6. Run "set_property INIT 1'b1 [get_cells b_reg]". Note this will make INIT as 1'b1
  7. Use "get_property INIT [get_cells b_reg]". It will return 1'b1
Arpan
Hello arpan,
    Thanks for reply.But i load this into fpga then how i can see the number?Suppose i have to write number 5 into register and have to see the 5 written correctly into that register?
Deepak
Hi @deepak1991,
You have to put some debug logic.
Either you can connect each bit to LED and see the pattern or you can use ILA / VIO to see the waveform or output respectively.
Arpan
Hii arpan,
please can you send me one example that i will understand clearly.And one more if i write a data into one register and have to transfer same data into another register and see the same data is getting out how to do this any idea?
