I would like to modify UARTLite IP.
Now the maximum bit width of the IP is 8bit.
I would like to send and receive 16bit data and 16bit data is synchronized by CLK.
I have tried to modify the UARTLite IP. I have completed to synchronize data and CLK.
But I couldn't change the maximum bit width from 8bit to 16bit.
If you know whether the maximum bit width can be increased by modifying UARTLite IP.
If your answer is YES, I would like to ask you how to do.
