Participant jacob.varghese
I2C EEPROM Interface with KC705 board
I am working on I2C interface. I am use xilinx sample code "xiic_eeprom_example.c" . When I run the code it seems to loop infinitely in while loop where it is check the status register condition.
I came across similar problem in this link, but problem not resolved
https://forums.xilinx.com/t5/Embedded-Development-Tools/Problem-with-xiic-eeprom-example-c-Virtex-5-using-microblaze/td-p/343299
Have anyone come across with similar problem?Can anyone tell me the root for this cause?
Re: I2C EEPROM Interface with KC705 board
This issue seems got fixed in vivado 2014.4 I would like to know which version you are using at your end
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
Thanks for Replying
I am using Xilinx 14.7, Can you suggest me any workaround for this problem.
Many Thanks
Jacob
@jacob.varghese
If you are using xiic_eeprom_example.c targeting KC705 board you are supposed to make the below change in xiic_eeprom_example.c.
* This define should be uncommented if there is IIC MUX on the board to which
* this EEPROM is connected. The boards that have IIC MUX are KC705/ZC702/ZC706.
/* #define IIC_MUX_ENABLE */
Did you uncomment this?
-Achutha
 Hello achutha,
It is uncommented.
MUX_ADDRESS                         : 0x74
CHANNEL                                    : 0x08
SLAVE ADDRESS(EEPROM)  : 0x54
Hello Balkrishan,
I tried with same code in Vivado 2015.2,but same issue prevails.
Please help me out.
Hello BalKrishan,
Sorry for my Ignorance......
I2C interface is working.Actually I didnot set MUX RESET PIN before.....
Can you Please State what is the Issue in PlanAhead 14.7 and other lower versions?
