Newbie akshaysarin
INTERNAL_ERROR:Xst:cmain.c:3423:1.29
I am getting the following error during the HDL synthesis of a project :
INTERNAL_ERROR:Xst:cmain.c:3423:1.29 -  Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Process "Synthesize - XST" failed.
I am not able to proceed further and diagnose the error.
I am using ISE 14.7 Spartan6 , LX-16  board for synthesizing. I have tried changing the "keep hierarchy" to "soft" and all other possible solutions I saw over the other community forums.
Please help!
Instructor
Instructor
Re: INTERNAL_ERROR:Xst:cmain.c:3423:1.29
My experience with XST is that it often crashes when there are errors in the user's HDL code.  I've found that ISIM can often flag the problem without crashing.  Are you able to simulate the code that's crashing XST?  Even if you don't have a top level testbench, you can run "Simulate Behavioral Model" on your top level module to see if you get compiler errors from ISIM.
-- Gabor
Newbie akshaysarin
I am able to simulate the behavioral model without crashing XST. So I think I don't have any compiler errors.
Instructor
Instructor
Any large loops in the code?  Sometimes attempting to create a lot of logic in one loop can cause a crash.
-- Gabor
    If inside of code using a bus type or any signal in different process or always block so the signal drives lot of resources so it will give this type of error,try to RTL code for design
    Try to use different signal for different sequential blocks
Newbie gafur_93
While i try to simulate in behavioral model i am getting error as "simulation flows are not supported for zynq based designs".
( I have added to xps to the top level module)
Note: I am using zynq 7045 model
Newbie gafur_93
Thank you.
Problem resolved.
