Visitor fdesla
IOSTANDARD value
Hi everybody,
Please, somebody could tell me how to determine the IOSTANDARD in an ucf file.
I'm working with a Zynq on a ZC702 platform (ISE 14.6).
Thanks for advance
François
Re: IOSTANDARD value
Please check page no 132 from below user guide for information regarding determining IOSTANDARD value
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/cgd.pdf
For datasheet of particular device, you can check below website
http://www.xilinx.com/support/index.htm
Ashish
Its very easy to use planahed pin planning method to loc the pin and assign associated IOSTANDARD.
You can open Planahed from ISE and then use this method.
Yash
you have all the information in the Xilinx employees' answers above, but just for you to have a graphical example, have a look at these two lines of one of my UCFs:
Ignacio.
Visitor fdesla
Thanks for your advices.
To determine the IOSTANDARD, It "only" depends on the pin not the use?
is there somewhere, something explaining for newbies how to choose the correct pin?
Thanks for advance,
François
Visitor fdesla
Thank you very much Yash.
Great help!
François
