nivin
ISE Window Closes
I have installed Xilinx ISE 14.7 on my machine. And have generated license file and added it. But when I try to create a new project, the design window gets closed. What may be the reason?
syedz
Hello @nivin,
This could be ISE crash. Can you try using ISE 32 bit executable and see if it helps?
--Syed
vemulad
Hi @nivin
Which OS are you using?
Ensure that you are using a supported OS. Refer to page-7 of http://china.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf for list of supported OS.
Deepika.
Deepika.
