ISim doesn't install
Hello. I loaded the full version of ISE using the 30 Trial Period option. I managed to complete a simple VHDL project, and downloaded it to my Spartan 3E- Starter Kit Board.
However, I cannot find any options to directly launch ISim. I did figure out how to set ISE to Simulation Mode and Run the Simulation, but I get this message:
"Model Technology's vsim executable cannot be found by Project Navigator. Please go to the 'Edit' menu...." (please see pic).
I did all of that, and I don't see the path for Simulation. I manually searched for the file 'vsim.*', but couldn't find anything. I read that it is part of the ISE Design Suite, but it doesn't work, or it wasn't loaded. I selected all options when installing, so I do not know what I could have missed..
Can somebody please tell me why ISim won't install, or run? Are there restrictions on the 30 day license? Where do I get that file "vsim.exe"?
Thank you, Richard V
HI,
It seems you have selected modelsim as target simulator while cretaing project.You should select ISIM as simulator to use ISIM.
You can change it from project settings.
Go to project Menu -> Design Properties -> change the target simulator to Isim.
HI,
You are The Man! Thank you.
Richard V
