Impact unable to connect to AC701 kit
I recently purchased the Artix-7 FPGA AC701 development kit and connected it to my computer. When trying to connect to the device using impact I get the following error: "There are many unknown devices being detected. Press Yes to continue or press No to stop". I pressed yes and get "Identify Failed". Below is a copy of the text appearing in the Impact console. How can I resolve this issue? Thanks.
INFO:iMPACT - Current time: 21 Dec 2016 21:51:20
// *** BATCH CMD : Identify -inferir
PROGRESS_START - Starting Operation.
Identifying chain contents...'0': : Manufacturer's ID = Xilinx XC7A200T, Version : 1
INFO:iMPACT:1777 -
Reading /opt/Xilinx/14.6/ISE_DS/ISE/artix7/data/xc7a200t.bsd...
INFO:iMPACT - Using CseAdapterBSDevice
INFO:iMPACT:501 - '1': Added Device XC7A200T successfully.
'1': : Manufacturer's ID = Unknown
INFO:iMPACT:501 - '1': Added Device UNKNOWN successfully.
'2': : Manufacturer's ID = Unknown
'3': : Manufacturer's ID = Unknown
'4': : Manufacturer's ID = Unknown
'5': : Manufacturer's ID = Unknown
'6': : Manufacturer's ID = Unknown
'7': : Manufacturer's ID = Unknown
'8': : Manufacturer's ID = Unknown
'9': : Manufacturer's ID = Unknown
'10': : Manufacturer's ID = Unknown
'11': : Manufacturer's ID = Unknown
'12': : Manufacturer's ID = Unknown
'13': : Manufacturer's ID = Unknown
'14': : Manufacturer's ID = Unknown
'15': : Manufacturer's ID = Unknown
'16': : Manufacturer's ID = Unknown
'17': : Manufacturer's ID = Unknown
'18': : Manufacturer's ID = Unknown
'19': : Manufacturer's ID = Unknown
'20': : Manufacturer's ID = Unknown
'21': : Manufacturer's ID = Unknown
'22': : Manufacturer's ID = Unknown
'23': : Manufacturer's ID = Unknown
'24': : Manufacturer's ID = Unknown
'25': : Manufacturer's ID = Unknown
'26': : Manufacturer's ID = Unknown
'27': : Manufacturer's ID = Unknown
'28': : Manufacturer's ID = Unknown
'29': : Manufacturer's ID = Unknown
'30': : Manufacturer's ID = Unknown
INFO:iMPACT - iMPACT quit the Identify Chain because it detects there are
at least 30 'UNKNOWN' type devices on the chain.
Please check the hardware settings and retry!
Hi @chogstro
Try latest version of iMPACT i.e., 14.7.
Reduce the JTAG cable speed and see if the issue still occurs.
Vinay
