hrmr0406
Inout Bypass Error
FPGA FAMILY : Spartan6
FPGA : XC6SLX75
In the interior of the FPGA, implementation of the Logic to become such as: Bypass.
DT is connected to the DSP side the Data Bus, D is connected to the Data Bus of different FPGAs the IC.
When you enter the DSP side Write Command, usually of Data is Masu Write, if you want to Read
Data is output for a while on Delay, I never read the Data that the DSP side firmly. (Attached figure)
Or not created in the above structure?
Or should the synchronization by placing the Flip Flop inside?
Tags (3)
hrmr0406
In the picture of wave wn , rb is not correct. it's just probing error. this is read command.
