Kudos for Newbies
When I joined the forum, a very kind user gave me my first Kudo. I want to pass on that kindness. If you are a Newbie and don’t have a Kudo yet, reply to this topic, and I will help you start you on your road to ranking and forum involvement.
Re: Kudos for Newbies
Hi @xilinxacct,
Getting the first Kudos might take time but their are some way newbies can get some:
  1. If you find a known issue and just report it, sometime moderators will give you a Kudos (at least I try to do)
  2. When you have an issue and you solved it yourself, share your solution with everybody (I think this deserve a kudos)
Then there is not secret method. To get kudos and build your reputation you need to answer questions from other members. But not only answer, answer with quality. Better your reply is (with screenshots, level of detail...) more chance you will have to get kudos from the author of the topic or from other members of the community.
PS: It shouldn't be ask for a kudos and get one else kudos would not mean anything
Florent
