Kudos not working?
Hi everyone,
   as a community partecipant I like to give kudos when a subject or reply is interesting and appropriate.
   But since the deployment of the new look and feel of the forums, I cannot give kudos anymore.
   Anyone else has noticed it so far?
Luca
Hello @colombini_luca,
Have you tried clearing your internet cache (Ctrl+F5) and also your cookies on Firefox? Sometimes that helps. Please try doing this, then close out Firefox altogether and re-open it again and then see if Kudos working now or still seeing the same behaviour? Please let us know the output. Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Community Manager
Community Manager
Hi @colombini_luca,
To give a Kudos not you have to click on the Thumbs Up Icon
That is working for me.
Sandy
Sandy
  unfortunately it is not working for me. I have signed in, but I get no feedback when pressing kudo button.
  Check with other users.
Luca
Hi @colombini_luca,
Yes it is not easy to see. But you should see the number of kudos increasing. There is not change in the logo like there was before.
Florent
Hi @florentw,
   trying to give you a kudo, but no increase so far. I am using Firefox 63.0.1.
Hi @colombini_luca,
This is what I see when I am not connected. Maybe try to clear your browser's cache and try to login again.
Florent
I have verified that in my case the issue is present when I use the Firefox browser.
Give kudos works fine when working on the same page with Chrome and Edge.
Please verify.
HI @colombini_luca,
I am using the following Firefox version and it works fine:
It really sounds like a cache issue. Please make sure you cleared the cache from Firefox
Florent
Just give you a kudo for your reply, but using Chrome!
I have cleaned up Firefox cache, but unfortunately still having this issue.
Not a big problema, but I would like to use it as well on Firefox.
On Firefox I don't get any feedback when pressing the thumb up hand symbol.
HI @colombini_luca,
Do you have touch screen option enabled for Firefox? I know I disabled it. This is the only think which I could think of...
Florent
Advisor
Advisor
Are you running NoScript? If so, enable addthis.com and Kudos should work again.
I don't know what NoScript is. Please explain @u4223374
Advisor
Advisor
NoScript is a Firefox plugin that blocks scripts (little programs integrated into web pages). This improves security and performance, but also tends to break a lot of websites. However, you can tell it to enable scripts for sites that you specify - on the Xilinx forums addthis.com is required to allow Kudos to work.
Hi @u4223374,
no, I haven't got NoScript Firefox plugin installed.
The problem still persist in my case.
No one shares?
Kind Regards,
Anatoli Curran,
Thanks @anatoli,
   the suggested procedure works!
Luca
Still flaky on Firefox 68.0.1; sometimes it works, sometimes it doesn't. Works Ok in Chrome. I don't have noscript or any third-party blockers, but 68.0.1 has built-in blockers which might be relevant.
