msh
Voyager
Voyager
LVDS output
I have implemented a simple program
ibrary IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity TDC_EvaluationSignal is
    Port ( Refclk : in STD_LOGIC;
           StopSignal : out STD_LOGIC;
           TDCrefClk : out STD_LOGIC);
end TDC_EvaluationSignal;
architecture Behavioral of TDC_EvaluationSignal is
signal StopSignalReg: STD_LOGIC := '0';
signal TDCrefClkReg: STD_LOGIC := '0';
signal counterReg: integer := 0;
signal TDCrefClkRegPrev : STD_LOGIC := '0';
begin
Generateclock : process (RefClk) begin
            if (RefClk= '1' and RefClk'event) then
                TDCrefClkReg <= not TDCrefClkReg;
                counterReg <= 1;
                    if (counterReg =1) then
                        counterReg <= 0;
                        StopSignalReg <= '1';
                    end if;
            end if;
            if (RefClk= '0') then
                StopSignalReg <= '0';
            end if;
end process;
StopSignal <= StopSignalReg;
TDCrefClk <= TDCrefClkReg;
end Behavioral;
In simulation I can see the signal, but after flashing in hardware I can only see TDCrefclk not stopSignal.
further I take this signal to generate LVDS output
But stil these LVDS outptu is not available at the set PINS
here is the pin configuration
There is a signal on Fclk and TDCcrefCk but not stop_signal. stop_signal_ p and TDCClk_p
May I know what wrong I am doing. How can I proceed ?
thank you
best regards
muzaffer
You have two options, one simpler and one slightly more complicated:
run the main clock at twice the speed and have stopsignal change at ever posedge & tdrefclk change at every other posedge to generate the timing you want.
If you can't run the input clock at 2x speed, you can use a DDR output cell (ODDR) for stopsignal and drive its inputs properly.
msh
Voyager
Voyager
Additional Information:
I am testing the output on oscilloscope.
Here is the schematic view of the program
thank you
muzaffer
@msh
            end if;
These lines are causing the trouble for you. Your description of StopSignal register does not conform to synthesizable subset. You need to change it so that you update it only on one edge of the clock.
msh
Voyager
Voyager
Hi @muzaffer
Thank you for pointing out the my mistake.
I would like to know if I want to initiate a signl and rising edge of clock and then want to make it zero at falling edge of the clock.
how should I proceed ?
thanks
msh
Voyager
Voyager
I changed the code to
                counterReg <= 1;
                        counterReg <= 0;
                        StopSignalReg <= '0' after 500ns;
                    end if;
            end if;
still it dont work
May I have your suggestion what should I do to get this waveform
muzaffer
