arivu01@
Max allowable operating range for XC6SLX150-L1FGG900I
We require the details of max allowable operating for the following
Part no: XC6SLX150-L1FGG900I
Max power dissipation(at 85°C)
Jc(junction to case) thermal resistance
Jb(Junction to board)
Ja(junction to ambient) values
Max allowable junction temperature.
Max utilization of the component in terms of percentage for 70°C and 85°C ambient temperatures
Kindly need your assistance for the above queries.
kkn
to calculate the max power either you need to use power estimator or if your rtl design is ready then use the xpa in ISE
http://www.xilinx.com/products/technology/power/xpe.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ug733.pdf
For the thermal values check the following link
http://www.xilinx.com/cgi-bin/thermal/thermal.pl
balkris
you can find information in device characteristic guide
http://www.xilinx.com/support/documentation/data_sheets/ds162.pdf
http://www.xilinx.com/support/documentation/data_sheets/ds160.pdf
http://www.xilinx.com/support/documentation/user_guides/ug394.pdf
Thanks and Regards
Balkrishan
