thisisobul
Multiple drivers error while connecting mmcm clocks to MIG
hai
i am using ml605 board, and i want to interface ddr3 ram with MIG, the MIG requires two clocks (200,400 MHz). so i generated from MMCM and interfaced to MIG then the error comming as the both clock lines has multiple drivers. i tried to solve by seeing other threads but its not happened. please give me solution
i tried the mmcm with and without output buffers
if i put output buffer error comming as multiple buffers in one line
if i remove buffer then error comming as line has multiple drivers
thanks...
vuppala
I suggest you to check the Technology schematic when the error was multiple buffers in one line.
Then write the buffer_type constraint on that specific net.
If using ISE, see the section buffer_type in the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/xst_v6s6.pdf
If using Vivado, see http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug901-vivado-synthesis.pdf
Vinay
smarell
Community Manager
Community Manager
Refer to the below threads for some inputs in resolving this error-
http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/Spartan-6-PLL-gt-MCB-Buffer-in-Series-problem/td-p/481160
http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/NgdBuild-455-Multiple-drivers-error-related-with-DDR2-clocking/td-p/484152
vsrunga
You can use MMCM with in MIG and derive required clocks so that it save additional MMCM.
Please check below link and follow the suggestions for modifying the RTL
http://www.xilinx.com/support/answers/35242.html
http://www.xilinx.com/support/answers/43559.html
 Hope this helps
-Vanitha
