gmvivek
Multiply and accumulation operation using DSP48a macro ipcore of xilinx Spartan -3A DSPs FPGA
Hi all,
I am trying to do a Multiply and accumulation operation of 256 values. For this I  have used 16  DSP48a macros, the ip core of Xilinx, Spartan 3A DSA FPGAs, each computing 16 MAC operations.
I have used (P+A*B) instruction to do the MAC operation. My implementation is correct before the MAC operation but it doesn't give the output.
is the problem with the IP core DSP48a macros??  Is my instruction (P+A*B) is correct for MAC operation?
please advise me.. thanks
muzaffer
NO.
In theory yes, but depends on whether you are using the DSP48s correctly. Are you driving the reset properly? What about various CE signals?
First try a very simple multiplier. If you just connect A & B with the CE's all tied high, can you get a multiplication output?
gmvivek
Hi Muzaffer
I can able to get an exact output with the IP CORE of  Multiply Accumulator version 2.0 but I couldn't able to get the ouput with dsp48a macro IPCORE.
The problem is with the control signals or instruction??  please advise me..
yenigal
You can find the control signal description from the below doc and check if you are driving them correctly
http://www.xilinx.com/support/documentation/ip_documentation/dsp48_macro_ds754.pdf
Satish
muzaffer
When you use P+A*B, you need to make sure that P register output is available/valid to be used in the addition. Try feeding A & B inputs continuously with no intermediate reset and see what you get at the output.
