linsheng
My posts always been removed, could anybody help?
After I post my questions, it seems everything is ok, but I can not find my post at the forum, could anybody help?
Best Regards!
Sheng
siktap
Hi Sheng,
I checked your profile and could see two other posts on the same issue in Timing analysis board. Copying one of them here which has been responded.
https://forums.xilinx.com/t5/Timing-Analysis/ISE-can-not-fix-the-hold-time-violation/td-p/827901
Are you able to access the above post?
Sikta
siktap
Hi Sheng,
Sikta
linsheng
Hi, Sikta,
Now I can see them now, thanks a lot!
billyjoe22
There may have 2 reasons 1) if you post duplicate post 2) if you post doesn't add value.
