NAND flash NV-DDR2 Interface with k7_325t fpga
  Recently, I designed NAND flash NV-DDR2 InterfaceIn fpga inside, rtl code is as follows
 IOBUFDS #(
          .IBUF_LOW_PWR("TRUE"),  //Low Power - "TRUE", High Performance = "FALSE"
          .IOSTANDARD("DEFAULT"), //// Specify the I/O standard
          .SLEW("FAST") // Specify the output slew rate
       ) OBUFDS_DQS (
          .IO   (nand_dqs_p      ),
          .OB   (nand_dqs_n      ),
          .O    (nand_dqsin      ),
          .I    (nand_dqs_ddr   ),
          .T    (io_ctrl     )
always @( posedge nand_dqsin or posedge rst )begin
    if ( rst )begin
        dqs_cnt                 <=  {8{1'b0}} ;
    end
     else if(cnt_clr) begin
       end
    else ifwr_dqs_en begin
dqs_cnt                 <= dqs_cnt + 1;
       end
end
 io_ctl signal control timing is right .
I found a problem, dqs_cnt and number of dqs signal that oscilloscope detected is unequal
dqs differential type, pin type is IO, level property DIFF_SSTL18_II, dqs pulse of 83MHz
Finally, I put IOBUFDS into single-ended, the problem is the sameFinally, I change the frequency (dqs frequency becomes 41.5MHz), there is no problemWhat causes this problem?thanks。
Hi Liuyong,
As per timing diagram when DQS is returned from toggling, it will be '1' state after last falling edge of valid DQS.
This may cause the issue.
