Anonymous
Not applicable
New to Xilinx want to learn more of the design tools
Hello, I'm new to Xilinx and want to know more about their FPGA design software and Soc design software. I've been using another company's FPGA's and design tools. I've been told that Xilinx SoC Design tools are way ahead of the other FPGA vendors so I want to learn more. Can anyone tell me what FPGA design tools I need and the SoC Design Tools?
Joe
Scholar austin
Re: New to Xilinx want to learn more of the design tools
Start here:
http://www.xilinx.com/products/design-tools/vivado.html
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar u4223374
Well, the main tool for FPGA design of any sort is Vivado. That's the Xilinx equivalent to Altera Quartus or Lattice Diamond. For the smaller devices you can use the free WebPack license.
For SoC work you'll probably want the Xilinx SDK, which comes with Vivado. You can also use HLS to convert (some) C code to HDL code for use on the FPGA. Both of these can use the free WebPack license (again, limited to small devices for HLS).
The "next generation" of SoC tools is SDSoC, which is meant to do much of the difficult work for you. You write a normal application in C/C++. SDSoC figures out which bits will get a big performance gain from being moved into the FPGA fabric, uses HLS to convert them to HDL code, connects the new hardware block as appropriate, writes all the drivers, and interfaces the drivers with the rest of the software. Unfortunately SDSoC is not free.
With that said, you definitely don't need SDSoC to work with a SoC. Vivado + SDK + HLS is a very solid combination of tools, and as far as I know HLS is well in advance of anything that a competitor can offer. The last I heard was that Altera was offering access to their HLS-equivalent beta versions if you buy one of the horribly expensive Arria 10 SoC or Stratix 10 SoC kits; with Xilinx you can buy a sub-$100 Zynq Snickerdoodle kit, use the free WebPack license, and get access to a relatively mature tool. HLS is not the world's most solid bit of software (it's still got a lot of annoying quirks and the occasional bug) but it's definitely at the point where it's worth using.
Anonymous
Not applicable
Thanks!
Hi @Anonymous,
If your issue is addressed, please close this thread by marking the appropriate answer as solution, so that it can help others who look for the same query.
Nupur
you can refer this guide
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug892-vivado-design-flows-overview.pdf
Thanks and Regards
Balkrishan
