peimann
Noob Question - Forum Display Motif
Good Day Folks,
As it appears that I shall be reviewing many forum threads while finding information on bleeding edge issues, I would like to make the reading of the forum easier on my tired, old eyes.
The default forum display motif is black-on-white [black text on bright, white background].
I tried working through all of the preferences, and I could not identify any straightforward mechanism to change the display motif.
I suppose that I might override the Xilinx style-sheet with one of my own, however that is really much more effort than I want to attempt.
So, is there straightforward mechanism which I might use to change the display motif from this painful, bright black-on-white to something a touch kinder to the optics, say green-on-black, or blue/gray-on-dark-gray?
Many Thanks,
The Noob
Peimann, S. M.
Kind Regards,
Peimann, S. M.
Toddlers are the Storm-Troopers of the Great God Entropy.
Physics: Not Just a Good Idea, It's THE LAW.
@peimann
You may be a noob but your question is hot (and unresolved) for many.  For example, <here> you will see that Xilinx is working on this for Vivado.
If you are using IE 11, you might try the following setting which seem to make the Forum colors a little kinder.
Cheers,
Mark
Tags (2)
peimann
I see that I have made the signature (.sig) error of a Noob - double signatures.
This waste of space shall not be visited upon you (meaning all of you) in the future.
You have my apologies for that.
Kind Regards,
Peimann, S. M.
@peimann
Cheers,
Mark
Tags (2)
peimann
Mark [markg@prosensing.com],
Thanks for the response.  You've confirmed for me that I didn't miss anything in the forum setup.
That'll definitely work, but it does (nominally) affect all pages from all sites.
I suppose that's the best option available to us at the moment.
Cheers,
Peimann
Kind Regards,
Peimann, S. M.
